225,000 $ Ford
88
Kansas City
1967 Ford Nite Mare FastBack. This is the car that Eleanor wants to be when it goes up. A serious Hand Built Custom Pro Touring Mustang. This is a Joint effort from two of the Top restoration Companies. Custom Classic Restorations in ILL,and Billups Auto Body in Oklahoma. The two shops worked together for 10 months to produce this truely incredible Pro Touring Mustang.
Nitemare
1967 Pro-Touring Mustang Fastback
Built by: Custom Classic Restorations , &
Billups Auto Body
ENGINE AND DRIVETRAIN:
Ford 358 cu. in. professionally built by Power Source in Fox Lake, IL
Dynos at 600+ Horsepower
SVO Block
Full roller motor
SVO fully ported aluminum heads
Billet Aluminum Valve Covers
Crower ultra-light 3.5 stroke crank
Fully ported to match Edlebrock intake
CP pistons 9.5 compression
Crower 6 1/8 rods
Jesel rocker arm system
Crower high endurance roller rockers
Custom ground roller cam
Titanium Dell West intake and exhaust valves
750 DeMon Carbuerator
Dry Sump motor
Weaver dry sump pump
MSD Ignition System
Be Cool Aluminum Radiator with cooling fans
Vintage Air Conditioning & Heat
McLeod Bell Housing
McLeod Aluminum Fly Wheel
McLeod Hydraulic Clutch
6 PUC clutch disc
Tremec TKO600 5 speed
Quartermaster steel driveshaft
1350 Quartermaster U joints
Stainless steel hand fabricated headers
Stainless steel 3 custom exhaust system
Stainless steel brake & fuel lines
Stainless steel fuel tank
Stainless E brake cables
Complete March aluminum pulley set
SUSPENSION:
Heidts Mustang II full suspension package and crossmember assembly
Air Ride Technologies air ride system & airbag support system
Currie 9 Ford housing 100% new, with 3:50 ratio & 31 spline true track differential. 1310 short yoke.
Wilwood 4 wheel disc brakes
Wilwood 6 piston aluminum calipers
Wilwood cross drilled front & rear rotors
Heidts adjustable proportioning valve
Heidts front sway bar
TIRES & WHEELS:
Throxton 20 x 10 rear wheels
Throxton 18 x 8 front wheels
Michelin radial 295/25ZR20 in rear
Michelin radial 245/35ZR18 in front
BODY:
Attention to panel fitting and all gaps
Shaved door handles
1 piece custom-fabricated door glass
Painted in urethane bc/cc black
Unibody tied together by Behind Bars Racing in Crystal Lake, IL
2 custom mini tubs in rear
INTERIOR:
All new leather interior
Seats are out of 2007 Mustang GT cutdown to fit
Handmade 1 of a kind custom center console
Autometer gauges with carbon fiber backing
Power windows
Power remote door poppers
Flaming River stainless steering column
Custom sound system
Keyless door entry
