Whistling here in dixie
3
atlanta ga
I have a 1999 323i that has never given me any trouble. But it has started whistling when I start it up in the moorning and lately it still whistles while I'm driving. What is that sound? I talked to the BMW repair guy and he said it might be a pulley. Duh I have no idea.
Big Daddy
10,446
PNW (Left) Coast
Maybe a vacuum leak, any change in performance? Get a mechanics stethoscope and listen to the individual parts (pulleys) with it and see where the whistle is coming from.
90
Calgary, AB
whistling noise
Hi there,
As big daddy said, it could be a vacuum leak. I think if not a vacuum leak, it could be the cyclonic valve (basically an oil separator, or like a PCV valve) located under the intake manifold, beside the throttle valve.
It's not an easy job to replace this piece.
If there's a vacuum leak, you can use brake cleaner or even WD-40 sprayed liberally over the air intake ducts, and listen for a change in idle.
Good luck,
Tiger
3
atlanta ga
oil intact ducts
Hi there,
Good luck,
Tiger
I'm scared to do that![8]
